...Tightened B nut fittings on both fuel vent inlets on bottom of aircraft, cut at 45 degrees with dremmel per plans and used epoxy to attach a piece of screen on each fitting. Used some Fuel Lube on threads of fittings and tightened B nuts. L fuel vent line is complete
