RON'S WEB SITE
RV-6A QB
Fuel pump labels, wire, AHARS deck riveted...
Labeled both fuel pumps, installed #14 wire from Aux fuel pump ground with extra length for ground tab on firewall. Did some more sanding on empennage fairing. Installed an adel clamp for throttle linkage under ECM bracket nutplate.
Over 40 label
Throttle linkage support
RV-6A QB Home
3742
A/C Hardware & Supplies
Ailerons
Brakes
238
162
fiberglass
92
208
166
Flaps
Flight controls
63
153
Flight controls
71
175
Fuel tanks/lines
Fuel tanks/lines
203
Hardware
Insturment Panel
115
279
149
Lycoming IO360
MT propeller
Painting preparation
Paperwork
Parts fabrication
Polishing
Rudder/Brakes
63
153
Rudder/Brakes
Shipping
Subaru Engine
Subaru engine
57
117
Systems
Trim tab
121
238
Trim tab
Weight & Balance
Wheels/tires/gear
43
90
Wheels/tires/gear
277
Wiring
71
175
Wiring
43
90
