Brief Description: Installed oil access door on upper cowling...
...Cut oil access door to proper size and removed area under door for access opening. Installed hinge on door and riveted to cowling. Built up area around door as necessary to fair aerodynamically with cowl. Attached two latches for opening access panel. Admired Rick's work.
