...Routed A/P wires thru 5/8" snap bushing in sub panel and added adel clamps along firewall. Added adel clamp on fuel pump housing and routed roll and pitch bundles thru hole Van's drilled in wingspar after adding 5/8" snap bushing in each side. drilled for 3/8 snap bushing under seats for roll servo and assembled wires into 9 pin dsub and attached. I may repin the wires to get rid of an 18" or so excess wire length. Routed pitch bundle aft thru snap bushings for elev. trim wires.
