Brief Description: Shortened pilot control stick...
....Used a tube cutter in the fullest open position to cut 5/8" more off pilot control stick for Infinity stick grip. It looks like the stick/grip will now in the most forward position clear the panel by 3/8 ". Drilled a 29/64 hole 1/2" from top of stick clocked for proper orientation. It would have been wiser to use a 1/8" drill all the way thru the stick before opening to 29/64. I also suggest a drill press for accuracy. Replaced panel for planning of switches.
