Brief Description: Ran #10 wire from Alt thru firewall...
...Crimped ring terminal on #10 wire from alternator through opening in firewall using UHWM 1" cut thin to fit inside firewall bracket & ran to vicinity fo 60 amp CB by volt/amp meter on panel. Spliced #16 wire to alt. feed and ran thru fitting to panel.
