Brief Description: Ran manifold line to engine & drilled ignition key
...Ran manifold tubing forward from GRT MAP box thru firewall exit. Drilled hole to install keyed ignition switch. Ordered electrical circuit breakers and parts from Wicks. I may return some of the non Klixon CB if they aren't needed.
