Brief Description: Removed Subaru ECU & wires from inside...
...Attempted engine start one more time before removing Subaru ECU & wires from inside of panel area. Clipped and labeled wires from ECU that connect to EIS or new SDS system. I no longer need nor will the new SDS support the OBDII function or keep alive function. The same with the ECU. The only remaining operational items on my Keep Alive circuit is the clock and EFIS clock.
