Brief Description: Installed nylon insert for alt feed...
...Removed torn grommet and replaced assembly with the nylon insert David Cox fabricated to prevent chaffing of line against stainless firewall. Drilled out bottom firewall GRD attachment 1/4" bolt to replace with 5/16 so that one negative battery lead and one engine ground lead can be placed there.
