...Met David Domeier at hangar to do some finalizing of plans for switches and bussed for panel. Fabricated folding door for ATC fuse blocks for the Main Buss and the Comm/Avionics Buss. Jeff McKee flew in and helped me run a 16AWG wire from Ignition to starter solenoid on the front of the engine. Installed vacuum fittings on engine. Drilled panel for PTT, 4 more cb, start switch and Batt Select switch.
