Brief Description: Ess. Bus bar installed, CB, labels, GPS tray mod .
....Installed more Klixxon CB and drilled anti rotation tabs on back of panel using a starter 040 drill just started, then a Dremmel flat 035 diamond bit to indent the panel back about 010 to keep the breaker from rotating. Drilled copper bar for CB attachments and installed more labels on back of panel for ease in assembling/maint. Modified GPS tray so that I can pull a pin allowing it to fold down. Drilled slot in center subpanel extension so that AOA push button won't conflict. It needs to be trimmed more.
