Brief Description: Completed Main bus tray, throttle, vacuum secured.
...Reworked Main Bus tray so that it is same length as before but slides out with the panel. Will attach to bottom of glove box with #6 screws. Unhooked throttle from engine and threaded thru new throttle bracket inside panel and reattached throttle to engine. secured vacuum lines to engine with screw clamps. Placed electric tape over ESS BUS so that I'll be less likely to tingle my finger under the panel
