Brief Description: EIS GRD, R fuel sender, ECU warning...
...EIS GRD wire routed inside loom and attached to 1/4 bolt on F/W GRD. R Fuel Sender wire attached to R fuel gage. Added an adel clamp near ECU for cable support. Both ECU warning lights labeled spliced and ran forward to "check engine" warning light. Ran #14 wire from avionics Bus to Av. switch. Added split loom to EIS wires behind subpanel.
