Brief Description: Modified R air vent to ease removal...
...Ordered sw. parts from B&C-washers with tangs & extra inst sw. retaining nuts. Drilled inst. sw. tang with 35 drill. Pulled panel out further for rerouty of wires and easier access to switches. Installed modified inst clips reamed for #8 screws to remove Rt. air vent so that panel can be removed. Rerouted Avionics switch to main bus, shortened wire and added new connector. GTX-327 power to avionics bus-fuse added. Redid Wag3 to taxi switch with longer wire. Reroute wires to switches for LDG/Taxi switch.
