Brief Description: Heater wires routed, A/P & dimmer power to fuse...
...A/P power wire run to the fuse tray on Avionics Bus (Needs 7.5 or 10 amp fuse). Fuel gage power wire run from R fuel gage to Main buse panel fuse. A double lug connector was used and the dimmer power wire will be connected also. Drilled 7/16 hole for bushing in subpanel for the heater wires to go forward to the heater switch. Both sides of subpanel were labeled. Ran #14 wire wire from heater fuse to heater switch. Ran #14 wire from Red High lug on heater to front panel. Also from low lug to panel. Added a sticky clip to rudder pedals brace to use tie wrap for heater wires.
