Brief Description: Redrilling and installing L aft canopy support...
...Redrilling and installing L aft canopy support...Removed aft canopy block and used as pattern to drill side screw holes on drill press. To move the aft portion of the skirt inboard, I was able to redrill the nylon block by drilling parallel to the other block as shown still starting at 40 and working up to 1/4" and move the attachment hole pin further inboard. To make the bevelled lead in curve I carved it with a box-knife rather than a larger drill.
