Brief Description: Drilled L plexi, both side braces...
...Drilled L plexi, both side braces...Measured rivet pattern on bottom inside of .016 side skirt braces, drilled to .40 and used as pattern to backdrill thru C-660 skirts into wood block from inside cockpit. The rivet line looks good from outside. Trimmed and polished L & R sideskirt joggle for better fit.
