Brief Description: Securing antenna for ELT& EIS wires...
...Drilled 9/16 holes in sidewall flanges for rubber gaskets to run antenna forward to the ELT from the rear mount. Installed a nutplate above radio & installed an adel clamp to secure antenna and give strain relief. The unit was moved about 1.5 inches further aft as the antenna wasn't as long as desired. bob Pickens mounted a new phone jack on the panel end which had been cut off to shorten and run forward thru the grommets, Rick Galati installed a set of larger snap bushings in F604to accomodate more wires for the AHARS unit.
