Brief Description: Riveted/bolted F681 plate to VS...
...Riveted/bolted F681 plate to VS...Remeasured triangle distance and discovered leading edge of VS had twisted left slightly in reference to CL on fuselage. Re-aligned and overdrilled to F681 plate, drilled F612 brace to #12 and bolted to fuselage and rear spar. Drilled F681 to 30 and installed 10 AV470-AD4-6 rivets. Used one 3/16 rivet in oversized hole.
