Brief Description: Drilled, bolted HS to fuselage...
...Drilled, bolted HS to fuselage...Drilled from 40/30/21 and measured distance from CL at Inst. panel at 136" to each side of leading edge of HS. Attached VS with C-clamps and nearly a 1/2" gap existsat F612 attach point.
