...Horiz. stab install prep...Trimmed HS shims to fit edges, drilled to 40, cut extended longerons off at rudder flange-needs filing. Drilled WD641 center post to 3/16-needs 1/4, drilled flat end for two 3/16 bolts, cut canopy rail in half as starting point, assembled both canopy rollers to detail A
