Brief Description: Fitting R flap rod thru fuselage...
...Fitting R flap rod thru fuselage...Expanded hole through fuselage bottom and side for bolt to slip upward so that flaps will fit flush. It does take pressure to hold them up. I shortened octagonal flap rod (from RV-9) to replace tube I initially fabricated. We riveted most of the bottom of the R wing end flange in.
