Brief Description: R wing prep. for setting incidence...
...R wing prep. for setting incidence...Removed and reinstalled R wing after creating more clearance on angled weldment for fuselage skin. Installed R gear weldment and put driftpins thru spar into R weldment. When the angle of incidence is ) with the 3 1/32 spacer, the distance is less than 1/2" between wingtips/centerline on F609. Still needs more clearance where wing sloping part of spar enters fuselage.
