Brief Description: Fitting top forward skin to fuselage...
...Fitting top forward skin to fuselage...Positioned top skin using cargo straps and drilled to center stringer, but it was too short by firewall for rivet line on left side. discovered centerline of a/c is left edge of center rib, not center of rib. Filled holes with oops rivets, then removed and moved skin forward about 3".
