Brief Description: Cut 3 holes for rudder bushings...
...Cut 3 holes for rudder bushings...polished edges, final bending of curve, fluted edge, spaced and drilled rivet line and pop riveted leading edge. Mounted on vertical stab. on shopmate for alignment, and placed top fiberglass cap on for fit check and photo op. Will require trimming.
