...Measured wing/tail distance...Looked at points causing conflict. The right wing rear spar forward sandwich is hitting the bottom flange of the inboard wing rib and the distance between that wingtip and the aft center si 1 1/4 longer than left. There appears to be a slight forward sweep which is also common. Moved left wing forward slightly and put spacer behind ...to hold the gap. Flaps will not fit without trimming next to fuselage, Cut out 2" of loops in piano hinge for center insert of hinge pins to facilitate entry.
