Brief Description: Removed R head to expose piston...
Removed R head to expose piston...which had a hole punched in it. My mechanic friend wants to put a short block in which would be the least expensive fix. The past two months my mind has imagined the worst and I have decided NOT to rebuild it but switch to a Lycoming. The cause may have been leaking collant, or a lean mix in the cylinder, but at this point what difference does it make Senator.
