We bolted the stand to Mark's table to assist in disassembly.. We did a compression check and 3 of 4 cylinders have exhaust leaks. The end play in the crankshaft is nil and the runout is less than .001.The engine was running last July when it was removed and obviously it would not have passed annual as is. We will either do a top end or replace all 4 cylinders.
