RON'S WEB SITE
RV-6A QB
Access panel & MT prop removal
It will be necessary for better access behind the instrument panel so I cut out two panels and will hinge and nutplate later. The MT Prop wires before cutting at the solder joint. Parts were clearly marked for reassembly for new owner.
Marking panels for cutting
Panels removed
MT Prop wires near brush
RV-6A QB Home
3742
A/C Hardware & Supplies
Ailerons
Brakes
238
162
fiberglass
92
208
166
Flaps
Flight controls
71
175
Flight controls
63
153
Fuel tanks/lines
Fuel tanks/lines
203
Hardware
Insturment Panel
115
279
149
Lycoming IO360
MT propeller
Painting preparation
Paperwork
Parts fabrication
Polishing
Rudder/Brakes
63
153
Rudder/Brakes
Shipping
Subaru Engine
Subaru engine
57
117
Systems
Trim tab
Trim tab
121
238
Weight & Balance
Wheels/tires/gear
Wheels/tires/gear
43
90
277
Wiring
43
90
Wiring
71
175
