Brief Description: Adjusted AFR for engine power SDS meter...
...Adjusted AFR for engine power SDS meter...Talked with Ross at SDS and he recommended setting the same number for 4750 and above rpm that I had for immediate lower numbers. The AFR was 10.2/1 at takeoff rpm with 180 set in. Set at 160. Cleaned wing areas for star insignia decals
