Brief Description: Installed aileron control stops...
...Installed aileron control stops...Used 1" diameter nylon bar and center drilled 3/16 hole and shortened bar to about 3/8" so that it contacts the aileron mounting bracket in the full up position. Did both sides so that each aileron up stop acts as aileron down limit stop for opposite aileron. Readjusted L control torquetube so that it eliminates a slight over center position of the bellcrank.
