Brief Description: Ran #10 wire from ALT thru firewall...
...Ran #10 wire from ALT thru firewall...Crimped ring terminal on #10 wire from alternator thru opening in firewall using UHMW 1" cut thin to fit inside firewall bracket and ran to 60 amp cb by volt/amp meter on panel. Spliced #16 wire to alt. feed and ran thru fitting to panel.
