Brief Description: Disconnected flaps/ailerons for adjustment...
...Disconnected flaps/ailerons for adjustment...Removed the flap bolt inside cabin to drop flaps to allow access for aileron linkage disconnect. Am working on aileron stops. Pulled L wingtip to recheck alignment of tooling holes in end rib with alignment of tooling holes in aileron-checks good. Disconnected roll servo of A/P and there is still a slight force required when lifting either aileron from the down position.
