Brief Description: Moved transponder antenna, installed plate...
...Moved transponder antenna, installed plate...Secured transponder antenna cable to gear crossbar with adel clamps, drilled hole for antenna thru bottom and secured. Attached the aircraft registration plate under L rear HS with pop rivets.
