Brief Description: More engine fuel/air ratio testing...
...More engine fuel/air ratio testing...Obtained permission from Curt to tie down at his ramp which has 3 points. Ran up to 3800 rpm but concern for the windscreen being only clecoed cautioned me not to go higher. I need to finish the panel, get the top skin on and permanently attach the windscreen. Recorded numbers for each setting from 1000 to 3750 rpm. Set idle adjustment at about 1200 rpm with set screw on throttle body.
