Brief Description: Installed overflow canister to firewall...
...Installed overflow canister to firewall...Modified 3" clamp to fit cannister and attached with #8 screw to firewall using a nylock nut inside aircraft. Installed nutplate under panel for #6 screw to accach fuel changeover relay to panel. Removed bulb assembly from L fuel gage and broke it removing it. Ordered 2 from Van's. Adjusted set nut for MT prop to engage sooner to prevent overspeed on TO.
