RON'S WEB SITE
Date:  6-26-2010
Number of Hours:  1.80
Brief Description:  Sanding empennage, cowling & more flox added...
...Sanding empennage, cowling & more flox added...Removed empennage fairing and added flox and reinforcement glass under bend area for strength. Removed the one #8 screw holding empennage fairing, filled HS hole with rivet and filled hole in fiberglass with flox. Installed a new #6 screw one inch aft. Finalized vertical hinge pins for bottom cowling and added nylon caps to keep them from chafing against the motor mount.
Hinge pin for bottom cowling
