Brief Description: Sanding and adding resin/flox to fill areas...
...Sanding and adding resin/flox to fill areas of empennage fairing. Seems to make a pretty good fit. Drilled the fairing and secured to HS and VS using #6 self threading countersink screws. Managed to get by with only 5 on each side.
