Brief Description: Preparing engine for geearbox upgrade...
...Preparing engine for geearbox upgrade...Drained coolant from engine by removing ET sensor from bottom of thermostat housing. Unbolted LR radiators from Engine mounting plate and removed coolant hoses and rad. air inlets. Removed Coil pack & bracket from engine. Lowered oil cooler. Removed starter. Unfastened nuts holding gearbox to plate and pried off exposing flywheel which will be replaced with a tortion model to help dampen vibration for the engine and gear box.
