Brief Description: Connecting more SDS wires for operation...
...Connecting more SDS wires for operation. connected Coil Grd to F/W GRD bus. Connected SDS ECU GRD wire to F/W GRD bus. Connected INJ. GRD to F/W GRD bus. Drilled 1/4 inch hole in panel above EIS Warning light for SDS Warning light and installed LED in panel. Put Diaelectic grease around rubber fittings and connectors for injectors. Attached vacuum to EIS MAP sensor and teed off for SDS MAP sensor.
