RON'S WEB SITE
RV-6A QB
Drilled 5/8" hole thru both webs of F604...
...Drilled 5/8" hole thru both webs of F604 using 12 #30 drill bit and then enlarged. This will allow a tee fitting to send Pitot pressure aft to the AHARS input for the EFIS system.
RV-6A QB Home
3742
A/C Hardware & Supplies
Ailerons
Brakes
238
162
fiberglass
92
208
166
Flaps
Flight controls
63
153
Flight controls
71
175
Fuel tanks/lines
Fuel tanks/lines
203
Hardware
Insturment Panel
115
279
149
Lycoming IO360
MT propeller
Painting preparation
Paperwork
Parts fabrication
Polishing
Rudder/Brakes
63
153
Rudder/Brakes
Shipping
Subaru Engine
Subaru engine
57
117
Systems
Trim tab
121
238
Trim tab
Weight & Balance
Wheels/tires/gear
43
90
Wheels/tires/gear
277
Wiring
71
175
Wiring
43
90
