Brief Description: Routing wires for SDS system...
...Routing wires for SDS system. Ran AFR gage wires back to subpanel, thru anewly installed rubber grommet, over the radio stack held in place with an adel clamp. I then routed them forward thru an enlarged opening lined with plastic so there will be easy access to the PLEX system box. ran the timing sensor wire under the air intake andit will go forward thru and over the arm holding the air intaker hose, along the firewall and in the center opening. I ran the wideband sensor up to the battery tray where we'll install a nutplate for an adel clamp and then it'll run up the firewall into the pilot side wiring entrance to the PLEX sensor box.
