Brief Description: Installed static line T-fitting which is 1/4" poly
...Installed static line T-fitting which is 1/4" poly tube that must be inserted in boiling water to get it over 1/8" line. Drilled holes for bushings to pass thru longerons on L side of fuselage. secured T connection with adel clamp.
