Brief Description: Removed R side skirt & aft 5 or 6 times to bend...
...Removed R side skirt & aft 5 or 6 times to bend ... it over PVC pipe and have about 1/4" gap now at the lower corners. I have seen a lot of airplanes no better than this. The best way for a great fit is fiberglass, but I've been told it is a lot of work. I drilled the greenhouse piece to the canopoy frame on each side. Drilled & clecoed the R side pieces together.
