Brief Description: Cut holes thru stainless firewall for heater...
...Cut holes thru stainless firewall for heater. Used 1/8" drill and unibit to expand holes to 1/2" and used dremmel to expand hole to accomodate heater unit radiator pipes thru firewall. The warm air will be expelled upward between the rudder pedals. I thought that would be better than dumping the hot air on the fuel pump area which will be underneath the motor.
