Brief Description: Drilled and enlarged 2 firewall holes....
...Michael helped me enlarge the brainbox access hole thru firewall by using die grinder with a steel knurled end and also a hand file. I drilled and enlarged a hole for the throttle cable and we installed the insert that surrounds the cable and allows it to operate freely.
