Bobs Ten
RV-10
Control System
4-21-2018
Fabricate Rudder Trim, Install New Flap Actuator
1618 - 2130
Using standard techniques, fabricate rudder trim bellcrank from 080 2024 sheet.
Install actuator and rod end bearings to verify fit and range of motion.
Unfortunately, I am short some 10-32 threaded rod so I moved on to the new flap actuator.
The new actuator has a built in potentiometer. This will eliminate the RAC POS-12 and the problems associated with it.
Remove old actuator.
Fabricate new mount brackets to replace the originals from 2024 angle using standard techniques.
Fabricate actuator mounts from 2024 1 1/2" angle per PH Aviation instruction.
Fabricate two aluminum spacers for actuator. Spacers are 5/16 ID, 3/4 OD, and 1/2 long. This allows clearance on the actuator.
Fabricate spacer for original mount. Spacer is 1/4 ID, 5/8 OD, and 1 3/8 long.
The next two entries will include the photos.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
