Bobs Ten
Date:  5-30-2016
Number of Hours:  1.20
Brief Description:  Replace TruTrak Servo Mounts with G3X
1548 - 1700
While the elevator bellcrank/battery tray was not installed, I decided to change the Tru Trak servo mounts to the Garmin mounts. Inspecting the roll mount, I found that the mounting bracket was nearly identical to the tru trak bracket, therefore I left the TT bracket installed. The servo attachment, however, was different. I removed the TT servo linkage bracket from the bellcrank.
The pitch servo mount was different so I removed the TT bracket and will install the Garmin bracket with the bellcrank/battery tray. Also, the linkage mounting hole on the bellcrank was different. I removed the bellcrank to provide access. I located the new hole position and drilled the bellcrank for an AN3 bolt using the drill press.
Prime pitch servo bracket.
