Bobs Ten
RV-10
Control System
3-7-2014
39-7.1>3, 39-8.1
Control System
1230 - 1430
Insert new control stick into base, verify coplanar with drill press table.
Final drill through base and stick using #12 drill.
Final drill control column using 1/4" drill.
Final drill stick base using #12 drill.
Debur all holes.
Face both ends of stick base brass bushings using Smithy lathe, verify length between 2 1/4" and 2 5/16".
Debrur ends of bushings.
Verify fit of stick base and bushing in control column.
Lightly coat bushing with super lube, insert busing in base, verify smooth rotaion.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
