Bobs Ten
RV-10
Wing Tips
2-1-2014
OP36-2, -3
Install Left Wingtip Light
1330 - 1530
Position light doubler centered on wingtip.
Match drill mount holes using #40 drill, cleco as drilled.
Scribe wingtip contour on doubler.
Remove doubler.
Trim doubler to final size using bench sander.
Debur and smooth all edges using bench sander, s/b wheel.
Final drill mount holes using #27 drill.
Position nut plates at mount locations.
Match drill nut plate mounts using #40 drill, cleco as drilled.
Remove all clecos.
Machine c-sink nut plate mount holes.
Layout wingtip cutout per plans.
Drill corner radii using step drill.
Remove cutout using permagrit tools.
Debur and smooth all edges using permagrit tools, 180 s/p.
Cleco nut plates to wingtip.
Rivet nut plates using p-squeezer.
Verify fit of doubler.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
